MT32-SPlite Quick User Guide
Posted: Mon Nov 06, 2017 8:08 am
MT32-SP-Lite provides basically 3 uses cases :
- 32 tracks live recording (like a true tape recorder from the 80's)
- 32 Tracks Playback
- Sound Pad / PLaylist management for live show.
STEP0 : after installation, you have to launch MT32SPlite and define a project name, and select one disk at least (that could be used for recording). On first run, you have to select the ASIO device (this can be a physical device or Voicemeeter Virtual ASIO driver as well).
STEP1: Recording is made simple by Track Arming and RECORD Button. Then you can decide to Record one or several track and playback others. Like on Multi Track Tape Recorder. The TimeLine View will show you different clips from your different take (EDL) and will let you define some CUE point and manage cursor position.
Re: MT32-SPlite Quick User Guide
Posted: Fri Jun 29, 2018 1:09 pm
by Gwydion
I'm sorry if I missed it, but I've seen the quick user guide, but I can't seem to find a manual anywhere! I've looked at all the versions and even the 3rd party website and can't seem to find one. Is there a manual available somewhere that I'm missing? The lite version is interesting but I'm a bit lost one where even to begin. Thanks!
Posted: Mon Jul 02, 2018 9:27 am
you can find the MT128 Reference manual on our support page
https://www.vb-audio.com/Services/support.htm
(it's also given on general information topic here):
https://www.vb-audio.com/mt128/MT128_Re ... Manual.pdf
