Hi, I wondered if there is a way to reorganize my macro buttons.
I created buttons but then removed a few and there are blank buttons. Can I move macro buttons to organize the button that have mapping ?
Please advise
Thanks
How to remove a macro button or remove blank macro buttons
Agent86
s2h
Re: How to remove a macro button or remove blank macro buttons
no way to physically remove the blank ones or rearrange easily
but the trick I found is to open the config file in a text editor
and then just go and manually number all the ones you have to fit the layout you are using
you can pre-plan on paper to make it easier
and then stretch the window to fit your size 4x3 5x5 etc
then save the layout
the settings are in an xml file
I like to use motepad++ to edit them
its setup as an 8x8
so if you only want to use a 5x5 on screen then you need to know that
1-5 is your first row(6/7/8 not displayed)
9-13 is your second row(14/15/16 not displayed)
17-21 is your third row (22/23/24 not displayed)
and so forth and so on
the xml looks something like this
I bolded the part you would change to map to where you want
(It stands out better if you are looking in an editor like notepad++
its setup as an 8x8
<?xml version="1.0" encoding="utf-8"?>
<VBAudioVoicemeeterMacroButtonMap>
<MacroButtonConfiguration x0='0' y0='7' dx='1321' dy='338' />
<MacroButton[b] index='1'[/b] type='0' key='0' ctrl='0' shift='0' alt='0' anyway='0' exclusive='0' trigger='0' xinput='0'>
<MB_MIDI b1='90' b2='33' b3='0A' b4='00' b5='00' b6='00' />
<MB_TRIGGER tchannel='0' tin='0.0' tout='0.0' tmsHold='100' tafterMute='0' />
<MB_XINPUT nctrl='0' nbutton='0' />
<MB_Name>Mute Mic</MB_Name>
<MB_Subname>Ch 1 Off</MB_Subname>
<MB_InitRequest></MB_InitRequest>
<MB_OnRequest>strip[0].mute=1
System.SendMidi("out1", "note-on", 1, 51, 10);</MB_OnRequest>
<MB_OffRequest>System.SendMidi("out1", "note-off", 1, 51, 10);</MB_OffRequest>
</MacroButton>
<MacroButton [b]index='2[/b]' type='0' key='0' ctrl='0' shift='0' alt='0' anyway='0' exclusive='0' trigger='0' xinput='0'>
<MB_MIDI b1='90' b2='34' b3='0A' b4='00' b5='00' b6='00' />
<MB_Name>Mic On</MB_Name>
<MB_Subname>Ch 1 On</MB_Subname>
<MB_OnRequest>strip[0].mute=0
System.SendMidi("out1", "note-on", 1, 52, 10);</MB_OnRequest>
<MB_OffRequest>System.SendMidi("out1", "note-off", 1, 52, 10);</MB_OffRequest>
</MacroButton>
<MacroButton[b] index='3[/b]' type='0' key='0' ctrl='0' shift='0' alt='0' anyway='0' exclusive='0' trigger='0' xinput='0'>
<MB_MIDI b1='90' b2='35' b3='0A' b4='00' b5='00' b6='00' />
<MB_Name>Talk to RC</MB_Name>
<MB_Subname>Not to Podcast</MB_Subname>
<MB_OnRequest>Strip[0].B1=0
System.SendMidi("out1", "note-on", 1, 53, 10);</MB_OnRequest>
<MB_OffRequest>Strip[0].B1=1
System.SendMidi("out1", "note-off", 1, 53, 10);</MB_OffRequest>
</MacroButton>
-Scott
yes, you can re-arrange buttons in the XML file, but you must keep "index" consistent.
