I installed the Potato 3.0.1.3 and it seems that I lost "Voicemeeter VAIO" along the road. Only the secondary and tertiary ports are listed.
I only see the "AUX VAIO" and "VAIO3" devices in Windows I/O ports to send my output to. I DO see all three devices under "Audio, Video, Gamecontroller"
What may have happened to the primary port?
Missing Vocemeeter VAIO device (AUX and VAIO3 are OK)
Re: Missing Vocemeeter VAIO device (AUX and VAIO3 are OK)
or windows enable / disable audio device option.
or installation problem, you may re-install it correctly:
viewtopic.php?f=7&t=688
