How to control patch insert on / off with Voicemeeter Macro Buttons
slantalpha
Post by slantalpha »
Voicemeeter has the ability to enable patch inserts for the different channels (Menu > System Settings / Options). Are we able to enable / disable patch inserts with Voicemeeter Macro Buttons?
In the Voicemeeter Banana user manual here on page 36, it says "Voicemeeter remote API also allows changing different configuration parameters: Patch and System Settings."
Does "remote API" here include Voicemeeter Macro Buttons?
Re: How to control patch insert on / off with Voicemeeter Macro Buttons
Hi. You can configure a 2-positions button in Macro Buttons to turn on/off patch insert for a channel. The parameter is Patch.insert[k] where k goes from 0 to 21. (There are 22 channels in total). See this example:
Insert Example.png (24.27 KiB) Viewed 6257 times
slantalpha
Andres wrote:Hi. You can configure a 2-positions button in Macro Buttons to turn on/off patch insert for a channel. The parameter is Patch.insert[k] where k goes from 0 to 21. (There are 22 channels in total). See this example:
Thanks! That worked :)
