Saved XML File Inconsistencies
Posted: Thu Sep 03, 2020 11:42 am
Using Banana & Potato
1. When the XML is saved for the Macro Buttons, the 3rd line node should not be terminated with />. It should simply end with > because the XML node is terminated at the 2nd to last line of the file.
2. When the XML is saved for the main VoiceMeeter Banana Settings, the 4th line is missing an attribute closing single quote.
The srasio attribute is not closed properly.
<MacroButtonConfiguration x0='-776' y0='859' dx='767' dy='682' />2. When the XML is saved for the main VoiceMeeter Banana Settings, the 4th line is missing an attribute closing single quote.
<OptionDev mme='1024' wdm='512' ks='512' asio='0' srasio='0 msA1='0' msA2='0' msA3='0' />
