Macro Button Question
Posted: Tue Sep 22, 2020 5:11 pm
Is it possible to set the state of a Macro button based on the position of a fader?
I am using an Akai APC Mini to control VoiceMeeter Potato. The only problem is there is no physical feedback to where 0dB is located. I'd like to turn on a light using the Midi I/O whenever the fader goes above 0dB however I can not find any way to do this.
An alternative option is using the Trigger setting in the Macro Button configuration but this is only Pre-Fader. Is there a way to change this to Post?
Either option would work though I would love to be able to use the Trigger separately as a "Clip Indicator Light." Any help would be appreciated.
