I have been using Voicemeteer Banana for past 3~4 months and never had an issue with it. After recent windows or voicemeteer update it self I just can't use it anymore. When I ever I try to play games or use discord it start to lag/chop the sound. I would appreciate some kind of help regarding this.
Mic - Blue Yeti
OS - Windows 10 Pro
Choppy/Lagging noise coming out of my microphone
Re: Choppy/Lagging noise coming out of my microphone
Hi. ¿Could you please share a screenshot of Voicemeeter and the System Settings / Options.. window?
Discord Voice Settings include a Mic Test button that you can use to test your Input and Output devices. Do you also get chopped sound when using that test?
This only happens in-game or discord. If I play back audio into my headsets no issue there and same with records. If video is recorded mic works there without any issues
https://imgur.com/BAbyIjk
https://imgur.com/aY389nJ
https://imgur.com/Me0zV0m
P.S Blue yeti mic is set as default because I can't use Voicemeteer right now
Hi. You have configured Voicemeeter correctly, trying to keep the same sampling rate on all the devices:
In the meantime, You can also try to use the fix suggested in this video which changes Priority and Affinity to a Windows audio process: https://youtu.be/71HrZfR_Fro
- Preferred Main SampleRate is set to 48000 Hz, which is supported by your main device (A1)
- Blue Yeti microphone is also configured at 48000 Hz
- Voicemeeter Output (apparently used as Discord Input Device) is also set to 48000 Hz
- Test using an increased WDM buffer size (2048 for example)
- If you turn on ►A1 on Hardware Input 1 you should hear your own voice on the headphones. ¿Do you also hear it choppy?
I want play mic through A1 I have no issues. It is only in game and discord.
