File already exists (Saving)
Posted: Mon Dec 28, 2020 4:14 am
by barium
File already exists. Do you want to replace?
This issue is persistent for years with Voicemeeter, even when changing the file name or changing the directory.
Re: File already exists (Saving)
Posted: Mon Jan 04, 2021 1:25 pm
what voicemeeter version ?
can you precise the workflow ?
Posted: Sun Jan 10, 2021 1:52 am
by barium
Last two versions that I'm aware of. Yes, it reproduces. Menu > Save Settings > [filename] > ... I have to change 'save as type' to 'all' and remove [.]xml from the name and it saves fine, then add the extension manually.
Posted: Thu Feb 25, 2021 9:16 pm
by mutantone
This bothers me as well. I thought it was normal behavior. I was going to make a feature request for a quick save hotkey or a timed autosave.
menu->save settings->choose file->okay->are you sure?->yes
I don't understand what barium said - "change 'save as type' to 'all' and remove [.]xml from the name and it saves fine" - I don't do that, I just double-click the filename and say yes to the overwrite.
v3.0.14
Posted: Sun Oct 31, 2021 3:38 am
by barium
mutantone wrote: Thu Feb 25, 2021 9:16 pm I just double-click the filename and say yes to the overwrite.
v3.0.14
that is not how saving is done. your method is completely irrelevant to the issue.
Posted: Tue Nov 02, 2021 4:00 pm
could you precise the problem , because i don't understand exactly what is going wrong for you.
(with what Voicemeeter version ?)
