Voicemeeter installation problem
alpha45
Post by alpha45 »
it was just to report that, with windows 10 64 bit v20TH, I was unable to start the basic version of the software.
After installing the software and restarting the system, the program opening icon did not appear in the VB Audio menu, but in addition to the other all functional ones, the installation one and not the launch one appeared, so if I clicked on that it asked me if I wanted to uninstall .
After several attempts I finally installed the software directly from the site without downloading the .zip file and it worked normally.
I hope it will help someone ...
Thank you
