Well, after the last update of the program, it crashes, many times and the screen that I leave in attachments appears, I have updated windows, I have to remove it from the windows tasks and sometimes even that does not start it again and I have to restart the computer
Well, after the last update of the program, it crashes me many times and the screen that I leave in attachments appears, I have updated windows, I have to remove it from the windows tasks and sometimes it does not start again and I have to restart the computer.
If you can help me with that bug, Garcia
Voicemeter crash
Voicemeter crash
- VB-AUDIO Virtual Audio Device Mixing Console Applicatiwwon.jpg (208.55 KiB) Viewed 7141 times
Re: Voicemeter crash
it crashes on what action ?
we know only one case of crash, please check you are not in this case:
https://forum.vb-audio.com/viewtopic.ph ... =430&p=912
I leave it for a while without using the pc and the audio goes away, when I see the voicemetter it crashes
could you post a screenshot of your System Settigns Dialog box ? (in Voicemeeter Menu)
