Failed to create audio file
LoneStar
Post by LoneStar »
When I try to use the recorder, I get the following flashing error message on the recorder progress line..."Failed to create audio file".
All other functions are working fine.
Re: Failed to create audio file
wow ! did you check the target disk ?
could you send a screen shot of the Recorder Option Dialog Box (see Voicemeeter Menu) ?
LoneStar
Post by LoneStar »
Thanks for your response.
Target was set to "Users\...\Documents\Voicemeeter".
Changed target to a temporary folder on a different hard drive. Recording worked...no error message.
Changed target back to the original default "Users\...\Documents\Voicemeeter". Works with that target now. Weird :roll:
Thanks for the help! :)
gamerscircle
Post by gamerscircle »
This happened to me as well.
One day it was working... then stopped.. the path is there.. I changed to a temp path, then it started to work.. attempting to change it back to the original and it fails to create the audio file.
