Change sample rate VM-AUX
sub6500
Post by sub6500 »
Hello all,
After an update my Voicemeeter AUX channel sample rate changed to "96000 Hz / 7168". This is causing higher latency although nothing is routing through that buss.
I have tried running the control panel inside the VB AUX folder in Admin mode and changed system preferred to 44.1 and rebooted. Voicemeeter VAIO buss is "44100 Hz / 7168", but the Voicemeeter AUX channel sample rate is still "96000 Hz / 7168".
I have also tried system reinstalls, with only Voicemeeter with no sound devices.
Is there a way to change the sample rate and buffer of this buss?
Thanks! VM Banana has been really great for my workflow, fantastic software.
Gigabyte Z270 k5
RME Babyface audio Interface - ASIO
Re: Change sample rate VM-AUX
yes by the related control panel application (installed with Voicemeeter).
run it as administrator (right click on it and select "run as administrator").
REBOOT after change.
