Limit Remote Gain to 0 dbfs
Posted: Sun Jun 24, 2018 12:44 pm
by BangDroid
Just a quick question, I am wondering what this menu option does.
Re: Limit Remote Gain to 0 dbfs
Posted: Tue Jun 26, 2018 12:51 pm
by Shark-2
It limit the Gain sliders to 0dB if you change it with something else than the Voicemeeter GUI.
For example if you use an midi interface to change it, the slider will max out at +12dB. With this option, it wont go past 0dB.
This is an very usefull feature (at least for me), because i dont want to go over 0dB and on my midi interface i cant see where the slider stands
