After upgrading to 3.0.0.6 from 3.0.0.5 (following recommended uninstall old, reboot, install new, reboot guidelines (also rebooted a second time for good measure after installation)), my Reaper installation no longer sees the Voicemeeter *AUX* Virtual ASIO driver specifically (other VM Virtual ASIO drivers remain visible/usable). Nothing has changed on the Reaper side of things and reverting back to Potato 3.0.0.5 fixes this issue so I'm assuming it's a bug and not a feature Windows Registry also doesn't show an entry for AUX at Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\ASIO and I can't find a CLSID for it (again, both appear for other "available" VM Virtual ASIO devices). I didn't notice any errors within Potato GUI itself or during installation, but if there's something specific you'd like me to check out I'd be happy to! Beyond that, unsure what else to test or look for.
Any help would be appreciated, thanks!
Potato 3.0.0.6 Voicemeeter AUX Virtual ASIO missing?
Re: Potato 3.0.0.6 Voicemeeter AUX Virtual ASIO missing?
VAIO 3 is perfect for DAW.
Use it.
Use it.
VAIO is also perfect.mipsou wrote:VAIO 3 is perfect for DAW.
Use it.
But VAIO Aux should be perfect, too.
That is the point, that Aux ASIO does not exist for him with Potato 3.0.0.6!
He waits for other users that have already applied update 3.0.0.6 to report, if they also have no Aux ASIO.
Ok, using Potato most users can switch to VAIO3.
But all regular Banana users (only testing Potato) would have a problem with a missing Aux ASIO, because they cannot use VAIO3 as an alternative!
Others that still use 3.0.0.5 (like me) want to know as well if 3.0.0.6 has an Aux ASIO bug or not.
The question is: Is it better to skip 3.0.0.6 and wait for 3.0.0.7 (bugfix)?
Or is his missing Aux ASIO problem a singularity on his individual system?
I could try 3.0.0.6, but I am too lazy for the expenditure to reconfigure channels, sample rates and latency in Win system settings and VAIO config twice, only to find out what others already know (people with 3.0.0.6 installed).
yes, we forgot the ASIO AUX in the Potato package.
we will propose an update to fix this next week (monday normally).
Appreciate the sanity check Looking forward to the update, thanks!Vincent Burel wrote:yes, we forgot the ASIO AUX in the Potato package.
