Cable C & D not in 64 bit folder?
Posted: Sat May 23, 2020 5:16 pm
So, when I install the Virtual Cable, Cable A, & Cable B, they are installed in Program Files. But, for some reason, I can't get C or D to install there. The 64 bit installers are there, but when I click on them, I - understandably - get the option to uninstall. If I do that, then the installers disappear - obviously.
I was able to specifically access the 64 bit installers for VC, A, & B. But the installer for C & D is a combined package. I'm wondering if I should use that to install, make a copy of the installed folders (which include the 64 bit installers), uninstall, and then reinstall each of the two cables individually using the 64 bit installers.
What's the best way to install Cables C & D to make sure I'm installing them as 64 bit? Also, is there a way to get the VoiceMeeter Potato devices installed using the 64 bit installers (VAIO, AUX, VAIO 3)?
I bring this up because I find that, often, I can't get C or D to work or I get audio issues with them.
