Voicemeeter Challenge Code Prompt after Windows Update
Posted: Sun Dec 13, 2020 11:07 pm
by lunarwolfspirit
Hi, I have purchased a voicemeeter potato license a while back and I encountered a challenge prompt after restarting my PC due to the Windows Update.
The challenge code seems to have changed from the one I originally received in my email so I can't activate the software. I have not replaced any hardware components nor changed my PC.
Any idea what could be causing the issue?
Re: Voicemeeter Challenge Code Prompt after Windows Update
Posted: Sun Dec 13, 2020 11:41 pm
Hi. Please review the information provided here: viewtopic.php?p=2863&sid=32b4b28bdfb1a1 ... c571#p2863
You can also contact VB-Audio using the WebShop form: https://shop.vb-audio.com/en/contact-us
Hope this helps.
Posted: Mon Dec 14, 2020 12:38 am
by lunarwolfspirit
Thanks - the regen worked. However, I'm building another PC in literally 1 week, will I still be able to move the license from this to the other?
Posted: Tue Dec 15, 2020 2:24 pm
This is not a question about VB-CABLE !
The Potato license is not transferable, you may buy another one or use your REGEN option to generate another Response code for a second PC.
For this kind of question, you may contact us by the webshop contact form:
