Recording, Asio4all or VB- Audio ASIO Bridge
Posted: Thu Apr 08, 2021 8:40 am
by Ient
To Vincent Burel,
I recorded a music playing on my pc using Mixcraft 9 Recording Studio x64 under its options for " Asio" for Asio4all & then " MME" using Input- 1 & 2 of VB- Audio ASIO Bridge, both's all other settings eg bit, Hz, latency same as the original song, I played both versions on the same area of the song for ~10 times, if I'm correct I heard Asio4all's significantly more similar to the original than VB- Audio ASIO Bridge's, even that it claims it's bit perfect recording, do you know is there any truth in this/ my mistake?
Thx very much.
Re: Recording, Asio4all or VB- Audio ASIO Bridge
Posted: Fri Apr 09, 2021 10:38 am
ASIO Bridge and HIFI Cable are bit perfect, but Windows Application connected to HIFI Cable can give different result according audio interface used (MME, WDM, MME, Direct-X) and mode.
if you need more help, you may describe the audio path precisely, with screenshot of different application settings page, involved in your audio path.
Posted: Sat Apr 10, 2021 6:45 am
by Ient
i. Sry I meant Adobe Audition 14, not Mixcraft 9( I've Direct X 12, win10 if it matters) .
The only setting to change recording device's below, " Playback and Recording" doesn't've any device, Hz, bit & latency settings,
Asio,
MME,
ii. Btw, in my music player, Jriver,
which VB- Audio Bridge setting, ie direct sound, WASAPI, or Kernal Streaming's bit perfect?
Posted: Sat Apr 10, 2021 7:32 am
sorry i see nothing on your screenshot.
i need to know the audio path parameter on
Player -> HIFI Cable -> Capture app.
(REM: if you use ASIO4ALL or DirectX, there is no way to be bit perfect... Windows app can be bit perfect only with KS or WDM exclusive mode interface).
Posted: Sat Apr 10, 2021 8:43 am
by Ient
What's your nick in your discord pls?
Posted: Mon Apr 12, 2021 4:10 am
by Ient
Vincent Burel wrote: ↑Sat Apr 10, 2021 7:32 am
i. I recorded under Adobe Audition settings
I. Asio4all
II. " MME" VB- Audio ASIO Bridge
A2. Btw, if I use WASAPI & exclusive control of this device using VB- Audio ASIO Bridge, it won't record.
A3. Asio4all recording control panel I use these settings below, why asio4all recording not bit perfect?
ii. Jriver music player as my screenshot no option bit perfect?
