How to use ASIO Bridge?
Posted: Fri Feb 01, 2019 4:07 am
Hi Vincent!
First of all, thank you for all your awesome work and great products.
I don't mean to bother you, but I'm a little confused about the proper use of the HiFi Virtual Cable with Asio Bridge.
I have a Focusrite Scarlett 2i2. When I set this in Voicemeeter Banana as the main Hardware Out (A1) using ASIO: Focusrite USB Audio I get terrible static, pops and clicks. I think you mentioned previously that this is because Focusrite is known for making bad ASIO drivers. Even when I increase the buffer to 1024 it does not resolve the issue.
I, therefore, set the main Hardware Out (A1) as WDM: Focusrite USB and generally it would work okay with a buffer as low as 256. But sometimes there would be static noise. So, I increased the buffer to 768 and this seems to work good, although I do have to restart the audio engine in VMB every once and a while as there will be static noise. I must say that I am a little surprised that I have to set the buffer so high considering I do have a pretty powerful high-performance PC. But, as I've seen you mention here and there, different set-ups require different configurations. I don't know if it<s important, but I'm also using Virtual Audio Cables A & B along with the standard VAC that comes with VMB. Maybe the more virtual audio cables that are used the more the buffer needs to be increased? Sorry, I'm not an expert with these kinds of things, LOL!
Now, I came across the HiFi Virtual Cable with Asio Bridge and I installed that as well. My main question, or point of confusion, is how to use Asio Bridge and what is the purpose exactly? In other words, would ASIO Bridge allow me to use the ASIO: Focusrite USB Audio as the main Hardware OUt (A1) in VMB so that I could set the buffer lower than 768?
I tried looking for documentation and YouTube videos but I'm not finding much about ASIO Bridge to help answer my questions.
Again, sorry to be a bother, but any help would be much appreciated
