Order of installations
Posted: Fri Oct 24, 2014 5:29 am
Say I want to install Voicemeeter Pro, ASIO Bridge/HiFi Virtual Cable, and one of the original VB-Audio Virtual Cables.
If I do so, then the VB-Audio Virtual Cable control panel seems to only control the Voicemeeter virtual input(s). It no longer displays "Virtual Cable Driver" at the top. I'm not certain it is working with the virtual cable at all.
Is there an optimal sequence to install these three items? (And how does adding the extra Virtual Cables A and B affect all this?)
I was trying to follow the directions for adjusting latency and got quite confused! (Especially since Voicemeeter has its own buffer settings - albeit not "Max latency" settings - in the Setting/Options dialog.)
I had set out to learn enough to make a video on it, but ended up just messing my own buffers up, and now the WDM buffers seem to set their own values - all higher than 512 - no matter what the A1 setting! Just a bit maddening, I'd say!
Thanks for steering me in the right directions with these questions. I'm trying to get the best latency I can for a multi-keyboard setup controlling both their own synths and some virtual synths and pianos in the computer.
I have a Focusrite Scarlett 2i2 ASIO USB interface and a MIDI interface.
Terry
Terry
