VB VAIO and VBVAUX CABLE control panels exhibit no output
Posted: Sun Oct 26, 2014 6:49 am
I have noticed that with the two VBCable control panels included with Voicemeeter Pro/Voicemeeter that there is no output evident unless I have the Recording Devices tab open (a fact I discovered by accident!)
Is that normal?
This is true even though I do have signal passing through Voicemeeter to an output device.
(Speaking of VBVMAUX_ControlPanel.exe and VBCABLE_ControlPanel.exe (the latter which, incidentally, I've renamed as VBVAIOCABLE_ControPanel.exe so I could run it concurrently with the regular VBCABLE control panel which has the same name).
Selecting the Playback Devices tab or closing the Audio control panel stops the output monitoring. I suspect this is because only with the Recording Devices control panel open are there meters monitoring the output levels, giving it an output. But why the A1 Hardware Out or B1 or B2 are not seen as outputs is unclear to me.
This is not true with the regular VBCABLE_Control_Panel.exe running with a virtual cable passing into Voicemeeter, but I imagine that is because Voicemeeter is a genuine output.
Terry
Is that normal?
Terry
