The short explanation is that i'm initializing a float with -35.0
currently i've set the hotkeys Vol++ and Vol- to run a function that should read the gain value and display a message box with the value. but even tho i change the value from voicemeeter GUI and try to update it again, it's still the initialized value, it's not changing at any point
;#NoTrayIcon
#Persistent
#SingleInstance force
#NoEnv  ; Recommended for performance and compatibility with future AutoHotkey releases.
#Warn  ; Recommended for catching common errors.
#MaxHotkeysPerInterval 99000000
#HotkeyInterval 99000000
#KeyHistory 0
#UseHook
ListLines Off
Process, Priority, , H
SetBatchLines, -1
SetKeyDelay, -1, -1
SetMouseDelay, -1
SetDefaultMouseSpeed, 0
SetWinDelay, -1
SetControlDelay, -1
SendMode Input  ; Recommended for new scripts due to its superior speed and reliability.
OnExit("cleanup_before_exit")
SetFormat, Float, 0.3
global volLvlB0 = -36.0
global VMR_FUNCTIONS := {}
global VMR_DLL_DRIVE := "C:"
global VMR_DLL_DIRPATH := "Program Files (x86)\VB\Voicemeeter"
global VMR_DLL_FILENAME_32 := "VoicemeeterRemote.dll"
global VMR_DLL_FILENAME_64 := "VoicemeeterRemote64.dll"
global VMR_DLL_FULL_PATH := VMR_DLL_DRIVE . "\" . VMR_DLL_DIRPATH . "\"
Sleep, 500
if (A_Is64bitOS) {
    VMR_DLL_FULL_PATH .= VMR_DLL_FILENAME_64
} else {
    VMR_DLL_FULL_PATH .= VMR_DLL_FILENAME_32
; == START OF EXECUTION ==
; Load the VoicemeeterRemote DLL:
; This returns a module handle
global VMR_MODULE := DllCall("LoadLibrary", "Str", VMR_DLL_FULL_PATH, "Ptr")
if (ErrorLevel || VMR_MODULE == 0)
    die("Attempt to load VoiceMeeter Remote DLL failed.")
; Populate VMR_FUNCTIONS
add_vmr_function("Login")
add_vmr_function("Logout")
add_vmr_function("RunVoicemeeter")
add_vmr_function("SetParameterFloat")
add_vmr_function("GetParameterFloat")
; "Login" to Voicemeeter, by calling the function in the DLL named 'VBVMR_Login()'...
login_result := DllCall(VMR_FUNCTIONS["Login"], "Int")
if (ErrorLevel || login_result < 0)
    die("VoiceMeeter Remote login failed.")
; If the login returns 1, that apparently means that Voicemeeter isn't running,
; so we start it; pass 1 to run Voicemeeter, or 2 for Voicemeeter Banana:
if (login_result == 1) {
    DllCall(VMR_FUNCTIONS["RunVoicemeeter"], "Int", 2, "Int")
    if (ErrorLevel)
        die("Attempt to run VoiceMeeter failed.")
    Sleep 2000
spoOpen := 0
; == HOTKEYS ==
loop{
	WinGetTitle, spotifyname, ahk_class SpotifyMainWindow
	if(spotifyname != "" && spoOpen = 0){
		DllCall(VMR_FUNCTIONS["SetParameterFloat"], "AStr", "Bus[0].mode.Repeat", "Float", 1.0, "Int")
		spoOpen := 1
	} else if (spoOpen = 1 && spotifyname = ""){
		DllCall(VMR_FUNCTIONS["SetParameterFloat"], "AStr", "Bus[0].mode.Normal", "Float", 1.0, "Int")
		spoOpen := 0
	} else {
		;do nothing
	Sleep, 5000
	ToolTip
Volume_Up::
	readVolLvl()
	;volLvlB0 += 1
	;adjustVolLvl()
return
Volume_Down::
	readVolLvl()
	;volLvlB0 -= 1
	;adjustVolLvl()
return
; == Functions ==
;DllCall(VMR_FUNCTIONS["SetParameterFloat"], "AStr", "Strip[0].B1", "Float", 1.0, "Int")
readVolLvl(){
	statusLvlB0 = DllCall(VMR_FUNCTIONS["GetParameterFloat"], "AStr", "Bus[0].Gain", "Ptr", &volLvlB0, "Int")
	if (statusLvlB0 < 0){
		MsgBox, Error: %statusLvlB0%
	} else {
		MsgBox, %volLvlB0%
adjustVolLvl() {
	if (volLvlB0 > 12.0){
		volLvlB0 = 12.0
	} else if (volLvlB0 < -60.0) {
		volLvlB0 = -60.0
	DllCall(VMR_FUNCTIONS["SetParameterFloat"], "AStr", "Bus[0].Gain", "Float", volLvlB0, "Int")
add_vmr_function(func_name) {
    VMR_FUNCTIONS[func_name] := DllCall("GetProcAddress", "Ptr", VMR_MODULE, "AStr", "VBVMR_" . func_name, "Ptr")
    if (ErrorLevel || VMR_FUNCTIONS[func_name] == 0)
        die("Failed to register VMR function " . func_name . ".")
cleanup_before_exit(exit_reason, exit_code) {
    DllCall(VMR_FUNCTIONS["Logout"], "Int")
    ; OnExit functions must return 0 to allow the app to exit.
    return 0
die(die_string:="UNSPECIFIED FATAL ERROR.", exit_status:=254) {
    MsgBox 16, FATAL ERROR, %die_string%
    ExitApp exit_status
FHex( int, pad=8 ) { ; Function by [VxE]. Formats an integer (decimals are truncated) as hex. NOT IN USE FOR NOW
; "Pad" may be the minimum number of digits that should appear on the right of the "0x".
	Static hx := "0123456789ABCDEF"
	If !( 0 < int |= 0 )
		Return !int ? "0x0" : "-" FHex( -int, pad )
	s := 1 + Floor( Ln( int ) / Ln( 16 ) )
	h := SubStr( "0x0000000000000000", 1, pad := pad < s ? s + 2 : pad < 16 ? pad + 2 : 18 )
	u := A_IsUnicode = 1
	Loop % s
		NumPut( *( &hx + ( ( int & 15 ) << u ) ), h, pad - A_Index << u, "UChar" ), int >>= 4
	Return h
