I have had issues on my network caused by the Apple upgrade to iOS14. I have resolved most of those issues by turning off the "Private Wifi" setting.
I have an iPhone X and an iPad-Mini that upgraded and now VBAN Receptor is not working. It runs on the device but does not seem to recognize the streams being sent to it. Is there a way to work around the issue caused by the Apple upgrade?
VBAN Receptor not working after iOS 14 upgrade
Re: VBAN Receptor not working after iOS 14 upgrade
yes, iOS 14 is blocking our current VBAN-Receptor apps... but we are working on an update to fix this problem...
should be solved in one or two weeks now i guess...
Sounds good. Appreciate the update.
