VBAN Buttons and Potato help
Posted: Fri Nov 06, 2020 8:54 pm
by traeb
Is there a way to have Potato connect to my home wifi network, even though my VPN is the default network for my computer? I would like to avoid needing to disable my VPN or changing the "IP Address To" field in VBAN buttons every time I use the app.
Thanks in advance!
Re: VBAN Buttons and Potato help
Posted: Sun Nov 08, 2020 8:26 am
surely, but what do you to do exactly ?
(BTW: last Voicemeeter version provides new function in VBAN like hostname and ping management...)
Posted: Sun Nov 08, 2020 9:08 pm
by traeb
My apologies; it is working for me now.
I was previously unable to get it to work, but I must have had another issue that I solved without realizing while switching between the wifi and the VPN.
