Vban receptor not outputting audio
Hi..Newbie here..just tried a test set up ..managed to get a stream working as can see it on meters on VBan receptor lite but no audio ..tried on two android devices and an ipadmini ..none work..can anyone help?
Re: Vban receptor not outputting audio
did you read this thread first?
viewtopic.php?f=6&t=443
yep...done all that stuff..I have it all set up with a stream running to the devices I can see the audio on the level meters on Receptor but there is no audio coming through the device speakers.
you tried the last VBAN Receptor version on IPad?
or do you use VBAN receptor Lite ?
it is receptor lite on ipad
OK got it working on ipad.....I reinstalled on pc and ipad ...put all the settings in and it worked!!!...
