VBAN Button configuration
Posted: Fri Mar 29, 2019 12:02 pm
by LightD31
I need help configuring VBAN buttons on my phone, Voicemeeter doesn't detect my phone and I don't know why. Could someone help me please ?
Thanks
Re: VBAN Button configuration
Posted: Tue Apr 02, 2019 8:41 am
Generally the problem comes from the Windows Firewall,
check there is rule for UDP on the wanted network IP-Address range.
you may remove IP-FRom in Voicemeeter VBAN Configuration dialgo box, to be sure to get request from everywhere.
VBAN-TEXT and VBAN-MIDI can work without IP-From (this is to allow multiple remoting points)
Posted: Sat Apr 06, 2019 10:36 am
by LightD31
There is a rule for UDP in my Firewall but it still doesn't work
- Capture.PNG (11.61 KiB) Viewed 42906 times
Posted: Sun Apr 07, 2019 8:56 am
strange you may try to de-activate your firewall the time to make a test...
or
1- shutdown Voicemeeter
2- delete all rules relaetd to Voicemeeter in firewall
3- restart Voicemeeter and allow network connections, also on public network (additional check box).
Posted: Sat Apr 20, 2019 3:23 pm
by LightD31
I have resolved my issue, you have to write SendText("vban1"... to use the first configured channel instead of calling it by its name SendText("Remote" in my case
Posted: Mon Apr 22, 2019 11:21 am
ha right! i did not see this mistake in your first post...
Posted: Sat Jun 20, 2020 11:48 am
by Zeroin
Hi, would anyone please point me to a vban TEXT button syntax for starting and stopping taperecording?
Posted: Sun Jun 21, 2020 1:25 am
by Matsumae
Zeroin wrote:Hi, would anyone please point me to a vban TEXT button syntax for starting and stopping taperecording?
page 37 has all the commands you're looking for
recorder.record | 0 (off) or 1 (on)| REC | 2
recorder.record | 0 (off) or 1 (on)| STOP | 2
recorder.record | 0 (off) or 1 (on)| PLAY | 2
would probably look something like this to start recording:
"SendText("vban1",recorder.record=1;);"
you probably could have started a new topic for this question instead of bumping an old one
Posted: Thu Aug 27, 2020 10:31 pm
by Zeroin
Thank you very much! I'll try this. Manual downloaded!
It is one issue still.. looking for workaround for making vban acceptor work in background on my android 9 miui11 Ones I got it working somehow, but now havig trouble replicating condidions.. %\
It allmost looks llike it has been restricted to run in background by design, and what I saw was just a temporary glitch. )
Posted: Sun Aug 30, 2020 7:37 pm
the first parameter can be only "vban1" or "vban2"
SendText("vban1" ...
SendText("vban2" ...
stream name is set in the VBAN stream configuration page.
