Voicemeeter Banana Freezes Constantly
ricoben3
Post by ricoben3 »
VM B freezes while in game/streaming constantly. The audio just cuts out and I have to restart the application to get it to work again. Its getting really frustrating. I attached my settings and stuff to this. I put it on default, so idk.
Re: Voicemeeter Banana Freezes Constantly
its usually a question of configuration: the device selected as output A1
more info on this topic: viewtopic.php?f=6&t=451
ricoben3
Post by ricoben3 »
I haven't changed any settings, this just started to occur out of no where.
if it's after a WIN10 update , you may re-install Voicemeeter
more info there: viewtopic.php?f=6&t=442
ricoben3
Post by ricoben3 »
I have reinstalled a million times. For some reason, Voicemeeter is working fine, but whenever I try to install voicemeeter banana it freezes
what is freezing ? the installation process ?
Voicemeeter Banana ? when doing somthing ? or just on launch ?
ricoben3
Post by ricoben3 »
VMB stops reading input and output. All input stop and all output stops until I restart VMB.
instead of restarting Voicemeeter, can go in menu to make a Restart Audio Engine ?
if yes, it means your device selected as output A1 stops working... after some how many time ?
maybe due USB power management or because the device shut down... or something like that...
ricoben3
Post by ricoben3 »
Yes I have to do a Restart Audio Engine. It stops after about 5 minutes or so. My USB power is fine, I only have 3 devices plugged in. USB to connect to my mixer, my headset, and my webcam. Should not be a power issue.
you may change the audio interface for this device and see if it helps (use KS or MME instead of WDM for example).
