Hello, this program is really good love it but i have some issues.
It feels like when music or ingame sound goes too low it stops sending, some music go down in volume, breaks after that it has to go up to a certain threshold to get send it out again.
Have i set up my things in the wrong way, any easy fix or is this a glitch in the software itself?
Heres a screenshot if it helps out: https://i.imgur.com/TXBbMXq.jpg
Tried to search for a solution on the forums, either formulated it wrong or no real solution.
Music/game sound fading
Re: Music/game sound fading
no the output meter (-48 dB) are just shorter than input one (around -60 dB)...
there is signal sent to BUS , but you cannot see it in master meter bar...
