Voicemeeter Banana Randomly crashes in the background
markaabo
Re: Voicemeeter Banana Randomly crashes in the background
Post by markaabo »
Vincent Burel wrote:if you use other virtual cable than VB-Audio Cable, we cannot help...
The problem is not with the other virtual cables because they use a driver controller which logs the drivers and there's nothing in they're logs so its nothing to do with the virtual audio drivers which aren't VB's so it must be Voicemeeter or the VB drivers or Someother random bug in windows as i have said i have tried with all programs but voicemeeter closed and it still crashes randomly
if there is no Windows notification about the crash it means it's due to an audio driver or device, simply stop working, or disconnecting.
if it's the device selected as output A1, then Voicemeeter is stopped and audio engine restart is required.
