i want to know if there is a possible way, to use 2 or more ASIO Devices in Voicemeeter.
Greetings Sebastian
Multiple ASIO Devices
Re: Multiple ASIO Devices
From my understanding and experience, there is no such software that can use multiple ASIO devices simultaneously.
The closest thing to that is ASIO4ALL which can combine several audio devices into one ASIO device, but results are unpredictable.
It could work for your specific situation, but then again, it could not.
In Voicemeeter you can use only one ASIO interface as main stream (output A1).
and use other audio device by using Windows audio interface (WDM, KS MME).
Is there any chance for the near future, that you will work on this topic?
Or do you believe it is even possible to do that?
no, it's possible, we have this technology ready.
but difficult to provide it without a full matrix...
anyway we have such project in stock... will put it on top of the stack
Insane, that is what i wanted to hear
i look forward to trying it out asap when it is out
Thumbs UP
Thumbs UP
This is an older thread, but the topic is probably still current.Vincent Burel wrote: ↑Fri Oct 09, 2020 12:38 pm no, it's possible, we have this technology ready.
Is this still something that is being worked on or have other things taken priority since then?
yes, the VB-Audio matrix is in progress.
