Good morning
I have a PC with two Ethernet ports and VBAN seems to alternate which port it uses after each login.
Is there a way to bind Voicemeeter to one of the IP addresses?
Voicemeeter - binding IP address for VBAN Host
- Contact:
Scott Maxworthy
Producer
Max Media and Entertainment
https://maxys.com.au
https://maxyphoto.com.au
https://nakedpunt.com
Producer
Re: Voicemeeter - binding IP address for VBAN Host
if you have 2 ethernet port configured on the same ip address range
the system could send some packet by the first port and some other by the second port.
if you are in this case, you may set one of your ethernet port to another address range.
