VoiceMeeter Banana, Transfer To Potato Help?
NorkDorf
Post by NorkDorf »
Hey there!
I currently run a 2 computer setup and use VBAN on both computers to transfer the audio between system. I am contacting you guys today to ask if it is easy or what I should know if I wanted to use Pototato?
I have more physical connections that I would like to connect and have played through another audio source due to this 2 computer setup....
Do I just install Potato on both systems and transfer the Banana VBAN and settings? Will it work that way?
That last time I tried to use Pototato it kept restarting my system for some reason..... If someone has experience with this that would be great! I just need Pototato for more physical connections.
