Dear VBAudio,
Thank you for this project.
Although, there is an issue with Voicemeeter Banana and Potato(these I tried).
It works okay when you connect a Bluetooth Headset while Voicemeeter is running, but it instantly crashes when disconnecting.
Version: Voicemeeter Banana 2.0.5.3
This is how it looks like:
What might this be?
Regards
Instant crash after disconnecting a Bluetooth Headset
Re: Instant crash after disconnecting a Bluetooth Headset
Hi. ¿What interface (WDM, MME, etc) are you using with your headset? I have experienced a similar behaviour when disconnecting a USB headset. This topic describes why Voicemeeter freezes when the USB device (using MME) is disconnected.
1- Voicemeeter audio engine is anyway stopped if the output A1 device is no more working.
2- for the "not responding" aspect, we know a single case to make this happen: check you are not in this case: viewtopic.php?f=6&t=430&p=912
