Hello forum
is it possible to use vban talkie as audioplayer on ios devices?
i would like to use talkie instead of the receptor to be able to listen to a stream from voicemeeter and to send music from audioplayer on another stream to voicemeeter.
Thanks for any hints, Otto
Talkie as Audioplayer
Re: Talkie as Audioplayer
yes, the Talkie can also receive a VBAN stream (can be selected in the menu dialog box).
otto.baer@hispeed.ch
Hello Vincent
Thank you for the fast reply. because of my bad english, you might missunderstood my question. let me try again
if i have installed talkie on my iphone, can i use the output of the ios musicplayer (or youtube) as source for the outgoing stream in talkie? the description does not give any information about the possible sources.
Thank you very much for the great product!
no, only the input device. For the moment we see no way to get audio from iPHone output.
