To Vincent Burel,
I recorded a music playing on my pc using Mixcraft 9 Recording Studio x64 under its options for " Asio" for Asio4all & then " MME" using Input- 1 & 2 of VB- Audio ASIO Bridge, both's all other settings eg bit, Hz, latency same as the original song, I played both versions on the same area of the song for ~10 times, if I'm correct I heard Asio4all's significantly more similar to the original than VB- Audio ASIO Bridge's, even that it claims it's bit perfect recording, do you know is there any truth in this/ my mistake?
Thx very much.
Recording, Asio4all or VB- Audio ASIO Bridge
Re: Recording, Asio4all or VB- Audio ASIO Bridge
ASIO Bridge and HIFI Cable are bit perfect, but Windows Application connected to HIFI Cable can give different result according audio interface used (MME, WDM, MME, Direct-X) and mode.
if you need more help, you may describe the audio path precisely, with screenshot of different application settings page, involved in your audio path.
i. Sry I meant Adobe Audition 14, not Mixcraft 9( I've Direct X 12, win10 if it matters) .
The only setting to change recording device's below, " Playback and Recording" doesn't've any device, Hz, bit & latency settings,
Asio,
MME,
ii. Btw, in my music player, Jriver,
which VB- Audio Bridge setting, ie direct sound, WASAPI, or Kernal Streaming's bit perfect?
Asio,
MME,
sorry i see nothing on your screenshot.
i need to know the audio path parameter on
Player -> HIFI Cable -> Capture app.
(REM: if you use ASIO4ALL or DirectX, there is no way to be bit perfect... Windows app can be bit perfect only with KS or WDM exclusive mode interface).
What's your nick in your discord pls?
Vincent Burel wrote: ↑Sat Apr 10, 2021 7:32 am sorry i see nothing on your screenshot.
i. I recorded under Adobe Audition settings
I. Asio4all
II. " MME" VB- Audio ASIO Bridge
A2. Btw, if I use WASAPI & exclusive control of this device using VB- Audio ASIO Bridge, it won't record.
A3. Asio4all recording control panel I use these settings below, why asio4all recording not bit perfect?
ii. Jriver music player as my screenshot no option bit perfect?
