VBAN Receptor mapping incoming stream to specific ASIO channels
STEPHANVS
I was playing around with a DAW clicktrack setup sending multi channel audio through Banana's ASIO input, relaying it through VBAN to a remote PC running Banana. This config works, as the receiving Banana is able to patch to specific ASIO channels. I was wondering whether I could use only the Receptor on the receiving PC, as I do not need the virtual devices, my only problem is, that even if the receptor can talk to ASIO, I cannot map to specific channels. Am I missing something? Thanks!
