Incoming Streams - None
sjc-or
Re: Incoming Streams - None
Yes, maybe it is a flakey adapter on my main computer. I switched temporarily to WiFi but the problem persisted, however it uses the same adapter card for both WiFi and ethernet. Even tried downloading the latest driver for the NIC.
sjc-or
Well, I replaced the network card and that didn't fix it either. I'm stumped
no, you may change the ethernet switch or/and cable.
we already got the case where the switch simply dies
or/and
the case where the ethernet cable connector was not well plugged (because not good quality connector).
or/and
sjc-or
Yes I had already changed the switch and the cable as well.
Tomorrow, I'm going to explore this:
https://social.technet.microsoft.com/Fo ... dows-10-os
Steve
Steve
well, just took a look but i don't think it is the problem (also we don't use multicast mode).
you may try with another PC (replacing the 134 one, the one not receiving audio stream) - to see what's happening.
or did you try to send audio to another device (iPhone / Android) with VBAN-Receptor Lite ?
sjc-or
No but my computer did this Windows update this morning and everything started working again. So I have to assume Microsoft Broke it a week or two ago and fixed it with this update
https://support.microsoft.com/en-us/top ... 8ed227b0aa
It looks like there was a cumulative update 20H2 also done but for some reason it doesn't show in the history but that might also have fixed it as the updates happened both this morning.
incredible
next decade is promising...
sjc-or
I spoke too soon. After reboot, it is dead again.
sjc-or
OK, back now Feature Update to Windows 10, version 21H2
Now that is is working, I think I will turn automatic updates off on both PCs
sjc-or
Rats, it was working a while ago and I reboot and now it is not working. I still have updates disabled so not sure what is going on.
