I have it set to record at 48k mp3
I can not change the depth to 24? its greyed out
After i record and open the file it is 32k not 48k
works properly with WAV but i do a 4 hour long show and the file would be huge compared to mp3.
Recorder Options Help
Re: Recorder Options Help
could you confirm you have the last Voicemeeter version ? what is your number ?
nicktherat
version 3.0.2.2
I can make a video demonstrating what i am experiencing if you want. its not a HUGE issue because i can just open, convert and export as 48k, but it would be nice if it ....worked properly?
I am also opening the file with audacity, not sure if that would matter.
24 bit does not exist for mp3, but you should be able to set the samplerate to 48kHz...
could you specify the context more precisely?
nicktherat
sorry for the squished screen (i have an ultrawide) but i think you can still read the important parts (let me know if you cant)
https://youtu.be/0BfJRc2PatM
i record in mp3 at 48k, open in audacity and project rate is set to 32, then i do it for wav and open in audacity and its set properly at 48k
maybe the mp3 kbps is too low to keep 48kHz signal in mp3 file.
try 192 kbps instead.
nicktherat
you are the winner!
