VoiceMeeter has some bad random audio crackles issues
MrKoddy
Post by MrKoddy »
Hello there,
From yesterday, my Voicemeeter Potato has some bad random audio crackles issues. I tried everything, updated Voicemeeter, changing drivers in the app, relaunching VoiceMeeter, reinstalling drivers and Voicemeeter. But it has has some bad random audio crackles issues and I have to restart Voicemeeter. How can I fix this issue?
Regards.
Re: VoiceMeeter has some bad random audio crackles issues
there is a dedicated topic on this subject:
viewtopic.php?f=6&t=451
MrKoddy
Post by MrKoddy »
I already did everything in the topic
you may go in Discord to find a helper who help you to check your configuration.
there is surely a way to fix your problem (Be sure to use the Voicemeeter latest version).
MrKoddy
Post by MrKoddy »
UPdated too, same issue. I noticed issue began while I activated TPM 2.0 for preparing a Windows 11 update, I don't know if it is related. It was more stable before.
stability problem in the windows sound can come from everything (but often from video driver or network driver activity).
in all cases there is usually a way to find a stable configuration with Voicemeeter (by tweaking buffer size, selecting right audio interface for output A1).
if you cannot find your working configuration, you may come on our Discord server: https://discord.gg/TF42rahAXS
