No audio through VBAN but chat and ping pass.
Soullesss
Post by Soullesss »
Hi all !
I need to use VBAN over the internet. I opened UDP ports 6980 in both routers, chat and ping do work, but there's absolutely no sound coming through. I tried both Voicemeeter and Banana, tried different destinations (A1, A2, A3, B1, B2...), tried entering destination public IP address and domain name instead, tried “Restart Audio Device", but nothing works... I made sure that VB-Audio entries are enabled in windows firewalls on both PCs.... Local audio plays back fine on both PCs.
I'm pulling my remaining hairs for this in desperation.... What can possibly be the cause of this?
Re: No audio through VBAN but chat and ping pass.
typical problem of Firewall .... check your firewall on both side, windows firewall first. Think also about some anti-virus or anti malware service that can add some additional firewall.
Soullesss
Post by Soullesss »
Vincent Burel wrote: Mon Dec 05, 2022 9:19 am typical problem of Firewall .... check your firewall on both side, windows firewall first. Think also about some anti-virus or anti malware service that can add some additional firewall.
What exactly should I check in Windows Firewall? There are several entries for VB-Audio and, I believe, Voicemeeter. And they are all green (enabled). Should I also add a UDP Port 6980 in Windows Firewall without specifying which program it should be mapped to?
I tried disabling Malwarebytes Anti-Malware that I have on both PCs, that didn't help.
ok, so in this case, you may post screenshot of your VBAN Dialog box for both points to let me check your VBAN configuration.
Soullesss
Post by Soullesss »
Here are screenshots of PC-1 (sending, Windows 10) and PC-2 (receiving, Windows 7).
PC-1 VBAN.JPG (240.55 KiB) Viewed 49787 times
PC-2 VBAN.JPG (279.84 KiB) Viewed 49787 times
Chat windows of both PCs
Soullesss
Post by Soullesss »
Windows Firewalls
PC-1 Windows Firewall
PC-1 Win Firewall.JPG (14.87 KiB) Viewed 49787 times
PC-2 Windows Firewall
PC-2 Win Firewall.JPG (21.11 KiB) Viewed 49787 times
Soullesss
Post by Soullesss »
Router Port Forwarding
Router Port Forwarding PC-1
Router Port Forwarding PC-1.JPG (11.33 KiB) Viewed 49787 times
Router Port Forwarding PC-2
Router Port Forwarding PC-2.JPG (13.61 KiB) Viewed 49787 times
ok, i guess you have checked the topic about VBAN on internet here:
viewtopic.php?f=9&t=479
REM: outgoing stream NET QUALITY does not need to be set in SLOW mode (you can keep on OPTIMAL).
you can right click on INFO column on outgoing stream to check it uses the same UDP port (6980).
if you don't find an option somewhere related to UDP stream quota or traffic limitation,
you will have to use WireShark or Network Monitor app to see if you really receive the VBAN packet on PC2
Soullesss
Post by Soullesss »
Vincent Burel wrote: Tue Dec 06, 2022 8:08 am ok, i guess you have checked the topic about VBAN on internet here:
Yes, I read that first.
Vincent Burel wrote: Tue Dec 06, 2022 8:08 am REM: outgoing stream NET QUALITY does not need to be set in SLOW mode (you can keep on OPTIMAL).
I tried all net quality settings.
Does the port that we should enter in VBAN window represent the port of the remote computer, or this port of this computer?
Soullesss
Post by Soullesss »
What does this error message mean? I need to stream bi-bidirectionally, i. e. from PC1 to PC2 one stream, and from PC2 to PC1 another stream. Should I set different ports on each PC? No other programs use this port. Is there a chance that two instances of Banana are running at the same time?
Error Message on PC1
PC 1 Port Error.JPG (209 KiB) Viewed 49737 times
PC 2 when PC 1 gives Port error message.JPG (238.86 KiB) Viewed 49737 times
