Say I have two USB microphones:
- A good quality shotgun mic which will be used as the main audio source, pointing towards the speaker. But this mic doesn't have noise cancellation.
- A cheaper microphone which will be pointing in the opposite direction to capture background noise.
How can do it with VB Audio Cable or Voicemeeter? (or using it together with other tools such as OBS).
The problem is I have noisy neighbors, they play music aloud, shout...
I'm just a tenant, and for work reasons I move quite often. I can't invest in isolation in a house that is not mine.
