Hi, I´m an electronic musician. I like to stream audio from youtube etc to VM in Ableton.
I get sound from my computer to Ableton but it's mixed with the audio that i already, recorded on the same channel.
help please
people from Sweden.
voicemetter use and manual
midihooker
Re: voicemetter use and manual
and yeah I´m a paying user
midihooker
or do I need bananaversion for this?
there is two workflow for a DAW connected to Voicemeeter:
1- your DAW is mainly used to playback in Voicemeeter so you connect it to Voicemeeter Virtual ASIO input.
2- your DAW is also used to record everything in Voicemeeter, then you may connect it to Voicemeeter Virtual INSERT ASIO device (warning , there is one for Banana , one for potato).
if you still have problem you may post screenshot of Voicemeeter (and your DAW audio settings) and show us what is the problem exactly.
