The 'Show App on Startup' option does not seem to work. If I unselect it, it continues to show on startup. Any ideas?
Thanks.
Voicemeeter Banana 2.0.6.8
Windows 11 Pro
Voicemeeter Startup
Re: Voicemeeter Startup
maybe because you did not activate the option show in systray , could you post your Voicemeeter menu screenshot ?
JazzCafe
I don't really want it in the systray but I would like it to startup minimised to the taskbar if possible.
if not in System Tray and launched without showing the APP.
how could you be able to show it ?
JazzCafe
Once it's launched it shows up on the Taskbar (Minimised) you can then click it to view it when needed.
ok, i note that !
