Matrix CLI
Andew212
Matrix CLI
Post by Andew212 »
Hello, is there a way to access the Audio Matrix CLI externally?
Eg, does it expose a TCP server on a certain port or anything like that?
I would like to be able to control it from another program.
Thank you!
Re: Matrix CLI
by VBAN-TEXT request only for the moment.
see second message:
viewtopic.php?t=588
Andew212
Re: Matrix CLI
Post by Andew212 »
Thanks Vincent!
However I am still a little confused. So once VBAN is on, it opens a UDP server on port 6980 correct?
And then I should be able to send packets to it using the TEXT type to send CLI commands?
Could you help me with an example packet? Once I get the first one I can go from there.
If I want to send the cli command Point(ASIO64A.IN[6],ASIO64A.OUT[3]).dBGain = 0.0;
Would I send a packet as below:
VBANR\00\00\10Point(ASIO64A.IN[6],ASIO64A.OUT[3]).dBGain = 0.0; //sent as ASCII
to port 6980 as UDP?
I am using packet sender (https://packetsender.com) to test, but if you could suggest something better that would be great!
Re: Matrix CLI
Basically yes, but if you don't program it, you may use MacroButtons (installed with any Voicemeeter).
and define you request like this for example:
SendText("vban1",Point(ASIO64A.IN[6],ASIO64A.OUT[3]).dBGain = 0.0;);
see user manual page 54: https://vb-audio.com/Voicemeeter/Voicem ... Manual.pdf
Andew212
Re: Matrix CLI
Post by Andew212 »
Thanks Vincent, I have got this working now.
My problem was I didnt realise that VBAN stream 1-6 were audio, 7 was MIDI, and 8 was ascii.
Used the correct VBAN stream and have control now.
One more question. I can set all the commands I want, but is there a way to query the state of a command without changing it? So like can I read the current state of a point in the matrix?
Thank you!
