Voicemeeter Win 11 stuttering
Vayss
Post by Vayss »
For some time now Voicemeeter has started to stutter under windows 10 and after an engine restart it sometimes works for 5 minutes sometimes more sometimes less.I actually need this to record videos Is there a fix for this?
Re: Voicemeeter Win 11 stuttering
you may tell us what voicemeeter version you are using and post screenshot of voicemeeter and its system settings dialog box.
Vayss
Post by Vayss »
I use Voicemeeter Potato Version 3.0.2.8 (64 bit)
Screenshot 2024-02-29 181637.jpg (331 KiB) Viewed 23758 times
you may try to select another audio interface for output A1 (for example change WDM for MME).
Otherwise we recommend to update to latest coming version: https://voicemeeter.com/voicemeeter-upd ... uary-2024/
Vayss
Post by Vayss »
I have installed the new version, at the moment it works with some sound stuttering. I had to set all outputs to MME. Windows 11 was not recognized. the sound "warps"
this is not expected. The installer does not make any difference between windows 10 or higher.
guess you have rebooted your computer after each steps.
Vayss
Post by Vayss »
after a while the stuttering starts again. I restarted after each step
this is not expected, i invite you to come on our discord server to let some helper check your configuration.
