Uninstall before update?
erix
Post by erix »
Hi there, I'm considering updating to the new 2024 version. Is it still needed to first uninstall everything before installing the new version, or can we now just install the new version on top of the previous one?
Thanks in advance, Erix.
ragnar.jensen
Re: Uninstall before update?
Post by ragnar.jensen »
Yes, the procedure is still
  • Uninstall old version
    Reboot
    Install new version
    Reboot
erix
Post by erix »
Thanks for the quick answer!
I was expecting it though :(
This is disappointing, as I'm afraid to lose my whole configuration.
Therefore I think I'll stay with my current version.
simply save your configuration first (Voicemeeter menu -> save settings).
and check your default playback / recording device after of course, the problem is more in the Windows behavior that can change default device when uninstalling or re-installing audio driver.
