Hey,
I have just discovered the goodness of Scenes in VM.
I have seven scenes configured.
I have successfully created a button to select a scene, 01, using the following:
Command.RecallPreset = "Default Setup";
I want to reference the Scene by the reference number such as 01 for the Default Setup. As I may want to change the name of the Macro Button.
Can I use: Command.Preset[01].Recall;
In this form it does not seem to work so what can I do better?
Thanks...
Macro Buttons Scenes
- Scenes-1.png (66.66 KiB) Viewed 82449 times
- Scenes.png (24.1 KiB) Viewed 82450 times
Re: Macro Buttons Scenes
Skip the leading zero and add an "=1" at the end.
This works for me:
Ragnar
This works for me:
Command.Preset[1].Recall = 1;
Ragnar
Brilliant, the (k) in the script confused me so I didn't try what you propose.
Thanks for that. I'll try it out.
I configured it the way you said but it currently doesn't work. It seemed to work when I initially created them but now all four of the ones I made operate the same way even though I have different settings.
Command.Preset[1].Recall = 2;
Command.Preset[1].Recall = 3;
Command.Preset[1].Recall = 4;
All Trigger the second entry which is Default -10db
Not sure what to make of it.
Presets are zero based, with the preset number inside the brackets.
The number 1 after the equals sign is a True/False or On/Off flag. 0 is False/Off and non-zero is True/On.
Many commands in Macro Buttons use them, e.g.
will mute strip #1 and
unmutes it.
Ragnar
Command.Preset[0].Recall = 1;
Command.Preset[2].Recall = 1;
Command.Preset[3].Recall = 1;
Strip[0].Mute = 1;
Strip[0].Mute = 0;
Ragnar
Thank you that works, I need a crash course in this coding. LOL
