Distorted Audio
Clif_Hawk
Distorted Audio
Post by Clif_Hawk »
Windows 7 64bit OS - 8GB Memory
Audio is distorted up windows startup
I have installed Voicemeeter Banana - It works well at times but then the audio gets distorted.
to rest the Audio all I have to do is click menu select "Reset Audio Engine"
At this time I have no Idea what is causing the distortion.
Does anyone have an Idea what could cause the program to become distorted
I have two Audio Cards VIA on-board and C-Media Corp. Using VIA for external Microphone the other is for all the other audio functions.
I also am using X-Peace
Does anyone have a idea of where to start looking for the problem.
I can be watching to a you-tube video and in the middle I hear a click and the the audio is distorted. (I am doing noting else)
Some programs I use Adobe Acrobat Reader, Avast, Auto desk 2009, Cyberlink, FireFox, Google Chrome, National Instruments, Nero 2014, Team viewer 11, VMWare
/// I may have stumbled onto what is causing the Trouble. Windows 7 64bit OS - 8GB Memory
Usually Audio is distorted on startup
Some programs I use Adobe Acrobat Reader, Avast, Auto desk 2009, Cyberlink, FireFox, Google Chrome, National Instruments, Nero 2014, Team viewer 11, VM-Ware
/// It Appears I may have stumble upon the Problem "Remote Packet Capture Protocol v.0 (experimental)" - "CACE Technologies" Under msconfig - Services TAB
If i am incorrect or should not have disabled this please let me know
Re: Distorted Audio
When you audio stream is not stable in the time,
it's usually due to the main audio device (selected as output A1).
Keep default settings and select your best audio device as output A1
ASIO if any, WDM/KS ... MME at the end
you can post a screen shot of your Voicemeeter System Settings Dialog Box to let me see if there is other possible problem...
Clif_Hawk
Re: Distorted Audio
Post by Clif_Hawk »
Added Image System Settimgs
Re: Distorted Audio
ok, if WDM Speakers (C-Media PCI... ) is not stable, try the KS interface of this device (if present),
otherwise select the MME one (set Buffering MME back to 1024).
