Page 2 of 2
Re: Auto Restart Audio Engine for all devices
Posted: Tue Feb 22, 2022 8:03 pm
by veron
Vincent Burel wrote: Mon Feb 21, 2022 9:06 amthe moment we have no process to detect audio device re-connection or device re-enabled.
I propose to not define the process of turning on or off the device. I propose to make a limited number of reconnect attempts so that the recovery does not continue infinitely. Unless of course it is possible.
I assume that if the function has been restored not all devices, but only as specified, for example, in my case, only A2 device, then this problem did not occur.
Or the third option, create a hotkey to quickly disable and enable the "Auto restart audio engine (All Device)" option. This option is not good, but it is better than nothing to solve the problem.
Posted: Thu Feb 24, 2022 7:59 am
by veron
Or it may be possible when switching the device to another monitor (Win+P) to determine and switch the disabled device into sleep mode so that the Voicemeeter does not attempt to be restored?
