Hardware Input 1 = Mic Input freezed after a while.
Re: Hardware Input 1 = Mic Input freezed after a while.
prettynice wrote:Again. Mic stopped after ca. 30 minutes working with the new buffer settings.
Will try another USB Slot now...
you can also try another interface: WDM, KS or MME
this problem is pending on system (or USB device, or driver or Windows management).
REM: for streaming , you have to validate your configuration on a significant duration... for example 12 or 24 hours.
it's a mandatory task to do on Windows to be sure that the configuration works.
