Any way to get a Gain slider OSD? [Now there is]
Jeffen
Post by Jeffen »
Pretty much what the title says
I really like the voicemeeter software, the only real gripe i have is the lack of an OSD for the gain adjustment.
Is this a possible future feature for the voicemeeter software? or does anyone have any idea how to do this utilizing macro buttons perhaps?
I don't need anything fancy, just a slider or even just the current gain spelled out in text every time it is changed.
Jeffen
Re: Any way to get a Gain slider OSD?
Post by Jeffen »
Actually just had a dream that this was a thing.
Woke up disappointed :lol: :(
js3kgt
Post by js3kgt »
So it took a bit of work but I was able to accomplish this using Volume² https://irzyxa.blogspot.com/
Basically I changed the volume buttons on my keyboard to use a custom key combo (CRTL+F3 / CTRL+F4). Then I created a macro in voicemeeter.remote to alter the Bus gains. Last I setup Volume² to use those key combos to alter the volume and that comes with the OSD.
Nice thing is you can use any of the OSD that the program comes with. It's a little workaround that I wish VoiceMeeter had built in.
Jeffen
Post by Jeffen »
js3kgt wrote:So it took a bit of work but I was able to accomplish this using Volume² https://irzyxa.blogspot.com/
Well dang, i also got it to work but it gives me the same issue as this topic i made a while back, while certain applications are focused like Chrome and Teamspeak 3 the volume2 overlay will show that volume is changing but the actual VB macro buttons will not activate.
Maybe i'm doing something wrong? do you not get this problem if a chrome window is active?
Jeffen
Post by Jeffen »
https://github.com/Frosthaven/voicemeet ... ows-volume
I just installed it today and it seems to have been created just a couple of weeks ago, so i guess bugs are expected.
Works fine so far though.
